Graphics + mouse-down + alert = boom
1694
06-05-2014 08:48 AM
ReneRubalcava
Esri Frequent Contributor
So I'm having some difficulty using the mouse-down event for layers.
If I have have an alert popup on a mouse-down event, the map pan gets stuck.
Here is a jsbin
http://jsbin.com/pixima/1/
I've tried manually firing off click events or other mouse-up/down events, but I can't get the map unstuck.
Has anyone come across this and more importantly, know how to fix it.
Thanks.
KenBuja
MVP Esteemed Contributor
I came across something similar to this when examining this GitHub demo. In the discussion, the author discovered
it was event bubbling that was causing the problem, fixed by using the Dojo event.stop(e) method.
derekswingley1
Haven't seen that before. I'll do some research and post back here.
KenBuja
ReneRubalcava
Ha, thank you good sir. event.stopPropagation() did the trick!
http://jsbin.com/pixima/3/
derekswingley1
Thanks Ken!
