Connecting External GPS Units
Document created by dmorgenthaler-esristaff Employee on Sep 9, 2015Last modified by EGibson-esristaff on Sep 16, 2015
Version 3Show Document
  • View in full screen mode
External GPS Receivers:
Here are our results from internally testing certain external GPS receivers.
GPS Receiver
Successful?
Dual XGPS150A Bluetooth GPS Receiver
Yes
Garmin Glo
No
Trimble R1
Limited
Bad Elf GPS Pro+
No
Altus NR2
No
Trimble ProXH
No
How to use external GPS receivers with Windows 10 devices:
  1. Set up a Bluetooth pairing between your Windows 10 device and external GNSS/GPS receiver.
  2. At the bottom right corner of the home screen of your Windows device, tap Bluetooth > Open Settings > COM port, in order to check the out-going port number of the external GNSS/GPS receiver.
  3. Download GPSDirect software from http://www.turboirc.com/gps7/ and start it. Enter the COM port number that you retrieved from Step 2 as well as the Baud Rate (e.g. 9600) and click Install. The GPSDirect app wraps the external GPS receiver as a location sensor for the Windows 10 system.
  4. Start Collector for ArcGIS. You should be able to access your location from the external receiver.
Note: External GPS receivers require an open sky environment to determine your location.
Future Plans:
In the near future we intend to support connecting to Bluetooth GPS receivers directly within the app (i.e., a third party app will not be necessary).
    Outcomes
