Resolving GeoNet Login Issues
Document created by timothy_hales-esristaff Employee on Jun 1, 2015Last modified by LBranscomb-esristaff on Nov 26, 2019
Version 3Show Document
  • View in full screen mode
Logging into GeoNet requires that you have an Esri Account. When logging in you may encounter one of the following errors:
Email address already exists
Error:
You are logging in with an email address that already exists in https://community.esri.com. Please login with the account already being used in the Esri community, or update your email address – https://my.esri.com
Cause:
GeoNet requires that each account have an unique email address. If an email address has already been established within GeoNet with another Esri Account, then you will not be able to add other accounts that use the same email address.
Solution:
  1. Log into My Esri with the "old username" account.
  2. Change the email address to something other than the current email address.
  3. Log into GeoNet with the "old username" account. This will sync the email change in GeoNet.
  4. Go to your profile to confirm the email address has been changed.
  5. Log out of the "old username" account from GeoNet.
  6. Log into GeoNet with the "new username".
Not enabled for Esri Access
Error:
Your account is not enabled for Esri access.
Contact your ArcGIS  administrator for more information.
Cause:
The Esri Account you are logging in with is attached to an ArcGIS Organization account that has disabled Esri Access.
Solution:
Contact your ArcGIS Organization administrator to have your account enabled for Esri Access. Some organization may not allow their accounts access, so you may need to use another Esri Account.
  1. Log into ArcGIS Organization (Administrator).
  2. Find the account under Members.
  3. Click the gear to access a list of actions.
  4. Click Enable Esri Access
5 people found this helpful
    Outcomes
