Notes of Editing Tin
6131
12-17-2014 08:08 AM
1. if you want to create a constrained Delaunay triangultaion and you do not want any edge to be densified:
            var pEnv = pPolygon.Envelope;
            ITinEdit TinEdit = new TinClass();
            TinEdit.InitNew(pEnv);
            ITinEdit2 TinEdit2 = TinEdit as ITinEdit2;
            TinEdit2.SetToConstrainedDelaunay();
2. what is the difference between hard and soft in esriTinSurfaceType or esriTinEdgeType?
see:15375 - What is the difference between TIN hard and soft breaklines?
3. what are the differences between line, clip, erase in ITinEdit?
line: normal
clip: delete the data outside a specified polygon, at the same time the data area is bounded by this polygon
erase: delete the data inside a specified polygon, at the same time the data area is bounded by this polygon
an edge on the boundary is not inside data area.
What if there are many polygons? I don't know yet.
4. methods of ITinFeatureEdit:
AddPolygon: insert a polygon into a Tin so that the edges of this Polygon will be integrated into the Tin (only in the data area). Before using this method, you should have already create Tin.
AddPolygonZ: insert a polygon into a Tin so that the edges of this Polygon will be integrated into the Tin.
We can take it as that, AddPolygon is used to make some rules for existing Tin, but AddPolygonZ is used as an element to create Tin. This should be analogous to AddPolyline and AddPolylineZ, I guess.
5. my example
            //generates some points
            IPoint ipt1 = new PointClass(); ipt1.PutCoords(0, 0); ipt1.Z = 0;
            IPoint ipt2 = new PointClass(); ipt2.PutCoords(1, 0); ipt2.Z = 0;
            IPoint ipt3 = new PointClass(); ipt3.PutCoords(0.8, 0.8); ipt3.Z = 0;
            IPoint ipt4 = new PointClass(); ipt4.PutCoords(0, 1); ipt4.Z = 0;
            IPoint ipt5 = new PointClass(); ipt5.PutCoords(0, 0); ipt5.Z = 0;
            //generate a polygon
            IPointCollection pCol = new PolygonClass();
            pCol.AddPoint(ipt1);
            pCol.AddPoint(ipt2);
            pCol.AddPoint(ipt3);
            pCol.AddPoint(ipt4);
            pCol.AddPoint(ipt5);
            IPolygon pPolygon = pCol as IPolygon;
            //set the environment of TIN
            //each point of pPolygon must have Z value, that is, Z must not be NaN
            ITinFeatureEdit pTinFeatureEdit = TinEdit as ITinFeatureEdit;
            pTinFeatureEdit.AddPolygonZ(pPolygon, esriTinEdgeType.esriTinHardEdge, 1, 1, 1, null);
            //add the polygon as the constraint
            TinEdit.AddShape(pPolygon, esriTinSurfaceType.esriTinHardClip, 0);
            //get TinEdge form TIN
            ITinAdvanced2 ptinadvanced2 = TinEdit as ITinAdvanced2;
            List<ITinEdge> ITinEdgeLt = new List<ITinEdge>(ptinadvanced2.DataEdgeCount);
            for (int i = 0; i < ptinadvanced2.EdgeCount; i++)
                ITinEdge ptinedge = ptinadvanced2.GetEdge(i + 1);
                if (ptinedge.IsInsideDataArea)
                    ITinEdgeLt.Add(ptinedge);
If you want to construct a TIN for a mixture of points and polygons, you should first add the polygons into the TIN. If you add the points first, then the TIN will be constructed according to these points and many TIN edges are also constructed. Now if you add a polygon, then an edge of this polygon could intersect an existing TIN edge. In this case, ArcObjects would simply split both the edge and the existing TIN edge by inserting a new TIN node.
Any suggestions would be appreciated.
Comments
nicogis
you also can create a incremental diagram Voronoi:
for example on add point in tin you can use pseudo code:
            IPoint pt = yourPointClass
            pt.Z = 0;
            ITinNode tinNode = new TinNodeClass();
            tinFeatureEdit.AddPointZ(pt, 0, tinNode);
            IPolygon pg = tinNode.GetVoronoiRegion(yourMaxExtent);
get adjacent point of point added:
                    ITinNodeArray a = tinNode.GetAdjacentNodes();
                    //remove feature with index in ITinNodeArray from featureclass polygon Voronoi
                    IFeatureCursor pCur = fcVoronoi.Search(qf, false); // not recycling
                    IFeature pFeat = pCur.NextFeature();
                    do
                        pFeat.Delete();
                    } while (pFeat != null);
                    //and add new polygon Voronoi
                    foreach (index of Node in ITinNodeArray)
                        ITinNode tinNodeCurrent = tinNodeCollection.GetNode(index);
                        IPolygon pgCurrent = tinNodeCurrent.GetVoronoiRegion(yourMaxExtent);
                        if ((pgCurrent != null) && (!pgCurrent.IsEmpty))
                            feature = fcVoronoi.CreateFeature();
                            feature.Shape = pgCurrent;
                            feature.set_Value(idxId, tinNodeCurrent.Index);
                            feature.Store();
Version history
Last update:
‎12-12-2021 03:36 AM
Updated by:
