This document is intended to respond to commonly asked questions received from users of the trace network. Please contact the trace network space owners to request additional questions to be added to the FAQ. (Last updated July 14, 2021)
The trace network was released with the ArcGIS Pro 2.6 release in July 2020 and was designed as a path forward for geometric network users who are not utilities or telecoms (those users should move to the utility network). The new network type uses a simple approach to network modeling with the benefits of the updated environment and implementation you find with ArcGIS Pro. The target audiences for the trace network are hydrology (streams), rail, and other disciplines.
Capabilities of the trace network with the ArcGIS Pro 2.6 release include:
The ArcGIS Pro 2.7 release introduced support for enterprise deployments with ArcGIS Enterprise 10.9 as well as named trace configuration capabilities to enable the storage and sharing of complex trace configurations in Pro and through web maps.
There are many similarities between the trace and utility network; however, key differences in functionality are present due to the different use cases targeted for each dataset. The below table outlines the key pieces of functionality which differentiate the trace network from the utility network with the ArcGIS Pro 2.7 release:
Plans exist to add the following capabilities in later releases:
Are there plans to provide training materials and tutorial to learn the trace network? I ran across the videos here and they were VERY helpful, but they are aimed at people familiar with the ArcMap geometric network. Especially would like to see a tutorial of how to load NHD into the trace network.
Thanks for this space!
@curtvprice We have a couple of ArcGIS Learn lessons in the planning stages at the moment to cover various usage scenarios. Within one, we aim to cover the conversion process, taking an NHD dataset and converting the existing geometric network into a trace network. Is this what you refer to when you mention a "tutorial of how to load NHD into the trace network." ?
I am finding that when I convert the Geometric Network to Trace Network in a fresh, unaltered download of an NHD HU 8 gdb, and then run Enable Network Topology, there are dirty areas which cause the trace to fail (unless I uncheck Validate Consistency). Upon examination, I cannot understand what makes it a dirty area. There should not be any topology errors in the NHD, right? I am trying to understand is this is an ArcGIS problem, an NHD problem, or just user error.
Have you experienced this @curtvprice?
The NHD does have 'microgaps' and almost-coincident nodes that can break things. I saw a demo of trace network in an NHD call a couple years ago when they disabled validating as you did to avoid these problems causing the network to fail. Based on that demo I think you did the right thing!
Can someone clarify if the Trace Network can be used in/with the trace widget in WAB and/or Experience Builder?
Thank you in advance,
Vanessa
@VanessaSimps, I have this exact same question. I posted it on the community forms if you have an answer.
