Arcade in ArcGIS Dashboards Beta
Document created by ngolabi-esristaff Employee on Apr 3, 2020Last modified by ngolabi-esristaff Employee on Apr 23, 2020
Version 4Show Document
  • View in full screen mode
The ArcGIS Dashboards Beta fully supports all map authoring customization using ArcGIS Arcade. In addition, the beta allows for users to compose Arcade expressions directly into ArcGIS Dashboards for both the list and indicator elements, enabling customization of how data points are rendered.
See the attached Arcade in ArcGIS Dashboards Beta document for help with authoring Arcade expressions in beta dashboards. Additionally, keep an eye out for blog posts on the ArcGIS Blog for walkthroughs, examples, and more.
Arcade in ArcGIS Dashboards Beta FAQ
In the list and indicator, can we use Arcade fields (i.e. attribute expressions) authored in the web map?
Attribute expressions written for the web map pop-up will render in the map’s pop-up and in the details element, but will not be available outside of those contexts. They use a profile specific for that context and execute on-click while expressions for dashboard elements use a different profile made for those contexts.
Can I use my Arcade fields to filter on or run statistics on?
Attribute expressions that were created for the pop-up are specific to the pop-up in your web map and are not fields on your layer. Applying filters and running aggregation statistics can be done only on fields defined for the layer. New fields can be created and values calculated for them.
Can I use featureSet functions in my expression?
Feature set functions (i.e., queries) are only supported in certain Arcade profiles. In web maps, they are supported for the pop-up but not for symbols or labels, as each have a unique context and way they are executed. In dashboards, they are supported in the map element's pop-ups and the details element but not in list and indicator elements, given their context and execution patterns.
4 people found this helpful
Outcomes
