ArcGIS Pro Roadmap - June 2018
Document created by relkins-esristaff Employee on Jul 2, 2018Last modified by KKramer-esristaff on Sep 17, 2018
Version 2Show Document
  • View in full screen mode
ArcGIS Pro 2.2 was released on June 26th, 2018 so it's time to update you on our roadmap.  But first I want to encourage everyone to update to Pro 2.2 and learn about all the new features and capabilities in this release.
Our goal is to build the best GIS software available. This ArcGIS Pro Roadmap* gives you a sneak peek of what we're focusing on for the near, mid and long-term of ArcGIS Pro development.
This gives our current estimate of when each capability will be released. Some new capabilities will be made available for testing through Early Adopters Programs prior to a release. We'll revise the roadmap throughout the year to ensure it reflects the latest information.
What would you like to see next in ArcGIS Pro? Share your ideas on ArcGIS Ideas.
* Capabilities on this roadmap are tentative and subject to change, delay, or cancellation. The continued development or release of a capability is at the sole discretion of Esri.
Current Roadmap (post 2.2)
July 2018 Roadmap
Near-term (next release or two)
  • Attribute Rule Enhancements – Additional user experience for creating and modifying rules, existing rule validation, and support for querying additional layers as part of calculation or constraint-based rules.
  • Dimensions - Create, manage, and edit dimensions in an updated format for the ArcGIS Platform.
  • Contingent Values - Ability to set domain lists based on attribute values of other fields.
  • Building Scene Layer – Publish buildings from Revit files as Buildings Scene Layers in the Web GIS and consume them by clients across the platform.
  • Reports - Generate and share multipage reports using grouping, summaries, and tabular information.
  • Offset printing – Color management, spot color support, and support for overprints and knockouts used in offset lithography and commercial printing processes.
  • Extract Locations from Text – Discovers & extracts geocoordinates, place names, and other critical information within unstructured text data
  • Dynamic Feature Binning and Clustering – Dynamic grouping of features in order to visualize areas with greater and lesser numbers of features when displaying data at varying scales.
  • Mobile Scene Package -  Create Scenes packages with 3D content that can be consumed across the platform directly or as published Web Scenes and Layers in the Web GIS.
  • 3D Interpolation - Supports prediction of ocean and atmosphere variables through 3D interpolation
  • Voxel Scene Layer - Explore large multidimensional space-time voxel cubes for scientific applications.
  • Parallel desktop geoprocessing using Spark- Spatial-temporal analysis tools that run across multiple cores on a single desktop machine, resulting in increased performance.
  • Deep Learning support for Image Analysis - Inference (detect objects and classify pixels) using selected deep learning toolkits and the raster functions framework as part of the Image Analyst Extension
Mid-term (next two or three releases)
  • Parcel Management - The new generation parcel fabric will introduce 2D/3D editing capabilities and a simpler more efficient approach for parcel maintenance. The new generation of the parcel fabric can be edited from the entire ArcGIS Platform and maintained using the new improved editing functionality of ArcGIS Pro.
  • Projects in the Enterprise – Share and collaborate more effectively with others in your organization.
  • Scatterplot Matrix-  Examine relationships between multiple variables in one visualization.
  • Layer blend modes -  control the appearance of layers by blending content using a variety of blending modes
  • Presentations - Create and share a collection of map and scene views along with titles, graphics, and descriptive text as presentations.
  • Animated symbols – Symbols that dynamically change to show the direction of movement, change in intensity, or fluctuations in value to support scientific temporal visualizations.
  • Materials - Cross-platform support for materials and texture properties to support reflectivity, roughness, and other renderer properties that will allow ArcGIS apps to assign realistic materials to objects in 3D scenes.
  • 3D Effects - The ability to apply glow, motion, and other shader-based effects as cartographic symbology to content in 3D scenes to communicate data directionality or magnitude.
  • GPS Support – Connect, collect data, and update positions directly from a GPS device.
  • Terrain Editing - Edit features participating in a terrain data set.  Add, remove and replace data referenced by terrains.
  • Trend Profile Chart - An exploratory spatial data analysis tool that examines global trends in data and is a useful precursor to geostatistical modeling.
  • 3D Mesh as Ground - The ability to use integrated mesh or TIN information as a true triangulated ground surface that would be more precise than our raster surfaces and allow structures such as tunnels and mines.
  • New Extensions
    • Aviation: Charting
    • Roads and Highways
Long-term (in the plan but we are not certain of the release at this point)
  • Physically based rendering - The ability to use material properties for smoothness, glossiness, roughness, and other characteristics to render realistic textures in 3D scenes.
  • Geoprocessing in the database - New options to run geoprocessing tools like Buffer, Spatial Join, or Select Layer By Attribute as spatial queries in supported databases.
 For more information on the current release of ArcGIS Pro visit http://pro.arcgis.com
    Outcomes
