Creating a Table of Contents for Anchor Links
Document created by CLoya-esristaff Employee on Jun 13, 2018Last modified by lfountain-esristaff on Dec 26, 2019
Version 4Show Document
  • View in full screen mode
There are times when your content may be incredibly long. So how do you structure your content and provide readers with simple navigation to the part of your content most relevant to the reader?
Three Steps for Table of Contents
Use Headers and Subheaders
The content toolbar has a drop-down menu that provides options for different header sizes. Think of your headers as an outline when you use them. Each header level is a level of importance.
heading drop-down menu
Use keywords
Keywords help readers that scan your content find what they are looking for quickly.
Optimizing Content with Keyword Placement
Use a Table of Contents
Content structure is important. As long as your content has headers, the Table of Contents will generate anchor links to each header. Read Best Practices for Writing Content to learn more about creating and organizing content.
  • In the content toolbar, select the More drop-down menu and click on the Table of contents
  • A gray image will appear in your content where the cursor is located. This is the code-generated table of contents. You will not see the Table of Contents outline until you publish your document or Save as a Draft. Each header will be linked based on the level.
Table of Contents Drop-Down Menu
table of contents outline
References to other content with Table of Contents
Highlights from the 2018 FedGIS Plenary
Live from the DevSummit Plenary
2 people found this helpful
    Outcomes
