The source code of the widget demonstrated in the online tutorial:
Create a ListView widget—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
When I added this widget to my WAB 2.6 version, I am getting an error: "TypeError: Cannot read property 'geometryType' of undefined. Suggestions please.
Hi, Christina
Probably the sample code article doesn't state it clear enough. So basically you need to added a web map that has a feature layer with a picture attribute, such as this one: Society of American Foresters National Convention (web map id: 0a0de46758e249b5be536200ba7f8df4).
After adding the web map, then you can use the settings page of the ListView widget to map the thumbnail and title fields to the appropriate attributes.
Since this is a sample widget, it doesn't have all the checkings to prevent the issues like you encountered. I can improve this sample widget and the tutorial in the future release.
Please let me know if you still have issues adding this widget.
Yiwei
Thank you. I had a feeling that this was the reason. I am brand new to WAB Dev edition. I am looking for all the training I can get. I am aware of Esri's training class.
Hi Yiwei
Could you please confirm that this sample in zip work fine with latest WebApp builder 2.16?
Thanks!
Regards,
Sergey
